It is currently Sun 24. Nov 2024 3:52:25
PostPosted: Fri 18. Dec 2020 20:58:38
Im currently trying to set up a good tail on my 700 Diabolo.
Im using the Spirit Pro with a Futaba T14SG.
I want to follow the Spirit Tuning Guide and i have a question about the 3rd step: Set Gyro Gain.
As far as i know this means to change the value on channel 5?
It's possible to set a value from -100 to 100 ,so where should i start?
And also i have the possibility to change a value in the Gyro settings of the T14SG. But this does not change a value in the channel overview. So for what is this value exactly?
Thanks in advance. :)
NZ2000
PostPosted: Fri 18. Dec 2020 21:02:29
Changing GYRO gain in the GYRO menu should work normally.
It is recommended to start with 50% gain. You can see how gain is changing the the Diagnostic tab.
PostPosted: Fri 18. Dec 2020 21:44:32
Thanks for the fast reply.
Now just for my understanding, what is the difference between the Gyro setting in my Transmitter(0-100) and the Head-Lock(-100-100) wich i control over a potentiometer on the transmitter?
I dont know which value i should change when?
Users browsing this forum: No registered users and 63 guests
cron
