Motor not starting, constant beeping from ESC https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=4442 |
Page 1 of 1 |
Author: | HeliMLM [ Wed 16. Dec 2020 8:02:22 ] |
Post subject: | Re: Motor not starting, constant beeping from ESC |
Hi, you have to calibrate the Esc when connected to Spirit RS unit THR port... just follow the Esc&Spirit manual on how to do this for your Esc. Actually your Esc is most probably not seeing any correct "0" signal on throttle channel. before you can do this: did you activate throttle channel #1 in Spirit setup tool? (channel setup). before this step your Esc will not see any signal on #1 nb: and do not forget to set failsafe after Esc setup is completed! |
Author: | ZeXx86 [ Wed 16. Dec 2020 8:29:27 ] |
Hi, it might be enough to recalibrate the ESC or just to lower the Throttle Range - Min. value. You can find it in the General/Throttle window. You can decrease the value from 1100 to 950 and see if it will initialize. Also make sure that your Throttle value is really at 0% in the Diagnostic tab. If it is too high, the ESC will not arm for safety reasons. |
Author: | Omegon82 [ Wed 16. Dec 2020 10:17:04 ] |
Thanks for the quick replies!! Will try as soon as i get home from work |
Author: | Omegon82 [ Wed 16. Dec 2020 20:53:49 ] |
decreasing the value to 950 did the trick! constant beeping went away at about 1050, and motor working Christmas flying! Thanks again!! |
