It is currently Sun 24. Nov 2024 4:12:32
PostPosted: Tue 15. Dec 2020 23:41:19
Just installed Spirit RS in my T-Rex 450LP Dominator. Followed installation guide/wizard and all good. Throttle assigned to Channel 1 and calibrated with my Jeti DS 12 (low stick=0, high stick=100). Used a separate battery for setting up the spirit unit.
Next step i connected my brushless ESC to motor and THR port in spirit unit. When connecting power to the system the ESC constantly beeps and no response when moving the throttle stick. I have done no calibration of the ESC after unpacking my ready to fly T-rex 450 (attached picture of the components in the package). I have been flying the helicopter with the components in the package but have now updated to Jeti DS12 transmitter and Spirit RS.
Please help!
PostPosted: Wed 16. Dec 2020 8:02:22
you have to calibrate the Esc when connected to Spirit RS unit THR port... just follow the Esc&Spirit manual on how to do this for your Esc. Actually your Esc is most probably not seeing any correct "0" signal on throttle channel.
before you can do this: did you activate throttle channel #1 in Spirit setup tool? (channel setup). before this step your Esc will not see any signal on #1
nb: and do not forget to set failsafe after Esc setup is completed! :)
cheers
Michael
PostPosted: Wed 16. Dec 2020 8:29:27
it might be enough to recalibrate the ESC or just to lower the Throttle Range - Min. value. You can find it in the General/Throttle window.
You can decrease the value from 1100 to 950 and see if it will initialize.
Also make sure that your Throttle value is really at 0% in the Diagnostic tab. If it is too high, the ESC will not arm for safety reasons.
PostPosted: Wed 16. Dec 2020 10:17:04
Thanks for the quick replies!! :)
Will try as soon as i get home from work :)
PostPosted: Wed 16. Dec 2020 20:53:49
decreasing the value to 950 did the trick! :) constant beeping went away at about 1050, and motor working :D
Christmas flying!
Thanks again!! :)
Users browsing this forum: Bing [Bot] and 56 guests
