Spirit System
Stabi Correction not working when unit vertically mounted
https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=4441
Author:  helinut [ Tue 15. Dec 2020 10:19:31 ]
Post subject:  Stabi Correction not working when unit vertically mounted
Ever since the release of 3.1 I have been struggling to enable Stabi Correction on my 450 Pro test helicopter fitted with a Spirit Pro and Geolink. I got the vibration levels down to below 50, and also tested the accelerometer sensor per Tomáš instructions, but if I turned on Stabi Correction it would just pitch violently to the right when trying Rescue or functions such as Position Hold. These functions worked ok without Stabi Correction, but I wanted the extra precision that this parameter offers.
It then occurred to me that:
a) the sensor testing had to be done with the unit perfectly level with the label facing upwards.
b) my unit was mounted vertically on the left side of the heli
c) the heli was pitching to the right
So the question arose in my mind whether the heli pitching to the right with Stabi Correction on was because the unit was trying to right itself? So I reconfigured the heli to have the Spirit Pro mounted horizontally, and guess what? It now Rescues perfectly and the Geolink functions work correctly as well.
Lothar
Author:  ZeXx86 [ Tue 15. Dec 2020 10:30:46 ]
Post subject:  Re: Stabi Correction not working when unit vertically mounte
this could happen if sensor calibration was made incorrectly or mounting position was not set properly in the General tab.
Behavior should be identical with any mounting position if everything is OK.
Were you performing accelerometer calibration previously?
Author:  helinut [ Tue 15. Dec 2020 11:20:33 ]
I only checked the sensor calibration, I sent you the result. I never did a recalibration. I only did the initial compass calibration.
My setting was definitely Vertical Reversed, and now is Horisontal. Rescue etc worked fine when just switching Stabi Correction off.
I could send you my before and after settings files if you wish.
http://www.phpbb.com/
