It is currently Sun 24. Nov 2024 19:54:21
PostPosted: Fri 04. Dec 2020 0:29:28
just tried to setup the spirit pro with the assistant. servos connected according to instruction (h4 90 degrees)
problems:
only ch 3 react to pitch (minimal servo travel)
only ch 1 react to aileron
see video
[youtube] https://youtu.be/U8H1VP8ulDg[/youtube]
how to solve the problems?
cheers
PostPosted: Sat 05. Dec 2020 9:05:12
please set Swashplate type to CCPM 90 Velos, not CCPM 90.
PostPosted: Mon 07. Dec 2020 14:03:12
problem is not solved with the velos setting.
Pitch: only CH 0 and CH 3 working
Aileron: only CH 1 working
Elevator: CH 0 and CH 2 working
Any new solution?
Cheers
PostPosted: Tue 08. Dec 2020 21:45:53
I am afraid, but something is still wrong in the setup.
It is very important to set CCPM 90 Velos and save the settings.
Then all servos must move when you are moving with Pitch channel.
Can you verify that Pitch channel is moving in the Diagnostic tab, please?
