Which swashplatetype https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=4396 |
Page 1 of 1 |
Author: | tomsl [ Sun 15. Nov 2020 22:52:47 ] |
Post subject: | Re: Which swashplatetype |
Hello what you are looking for is on the EXPERT SETTINGS page. Cyclic phase: The value indicates the angle by which the swashplate is virtually rotated. For example a value of 90 will rotate the elevator to aileron. This feature is recommended for models with multi-blade rotor heads. For most other models, we recommend a zero value. |
Author: | Diamondblack [ Sun 15. Nov 2020 22:58:34 ] |
Have try this to change to minus and plus 45 but it will not work |
Author: | ZeXx86 [ Mon 16. Nov 2020 8:30:16 ] |
Hello, for sure it can work with Phase angle rotation. We have many scale pilots with similar helicopters. If not +45° then -45° can work. Then only correct servo reversing is needed. |
Author: | Diamondblack [ Mon 16. Nov 2020 15:45:23 ] |
okay will try again. Can you say me how i have to plug in the servos then? Servo ch number on spirit front left ? front right ? rear left ? rear right ? that will be great! |
