Spirit System
Update from 3.1.10 to 3.2.0 for motor tail?
https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=4360
Author:  Kluftinger [ Tue 27. Oct 2020 18:25:33 ]
Post subject:  Update from 3.1.10 to 3.2.0 for motor tail?
I'm running a µSpirit with a motor tail.
Everything is working fine so far with the special firmware 3.1.10
Does the new 3.2.0 firmware include all the goodies for the motor tail from 3.1.10? :?:
Author:  horneteer [ Tue 27. Oct 2020 20:28:10 ]
Post subject:  Re: Update from 3.1.10 to 3.2.0 for motor tail?
What goodies are in 3.1.10? I'm using 3.2.0 and my tail motor spins up even when throttle hold is on.
Author:  tomsl [ Tue 27. Oct 2020 20:48:04 ]
Hi
I am using 3.2.0 and my tail motor does what it should!! (Trex 150)
Author:  horneteer [ Tue 27. Oct 2020 21:15:28 ]
Thanks for the info - may be my setup then. Will take another look at throttle hold value. Can't think what else it could be (also on a Trex 150 but with non-standard escs).
Sent from my SM-G925F using Tapatalk
Author:  Kluftinger [ Tue 27. Oct 2020 22:26:36 ]
Please read this post: viewtopic.php?f=24&t=4259
Author:  horneteer [ Tue 27. Oct 2020 22:40:55 ]
Thanks Kluftinger - I'm using a heli version of blheli in the tail esc but but don't think there's any settings that would cause the tail to spin up at full speed when throttle hold is on. It seems the uSpirit doesn't detect that throttle hold is on.
Sorry for derailing your thread!
Author:  ZeXx86 [ Tue 27. Oct 2020 22:49:34 ]
I am afraid the problem is in configuration. You can simply try to connect a servo at the CH4 port and see what is really happening.
Author:  horneteer [ Tue 27. Oct 2020 22:57:40 ]
Ok will go over everything again. What should the throttle value be on the monitor page when throttle hold is on? Mine shows -0. Should it be lower than that?
Author:  Kluftinger [ Wed 28. Oct 2020 9:23:45 ]
@horneteer
My spektrum radio has a range from -100 to +100.
Throttle hold is at -130.
@ZeXx86
Does fw 3.2.0 include every changes of 3.1.10
http://www.phpbb.com/
