Question about additional SRXL2 Satellites... https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=4344 |
Page 1 of 1 |
Author: | Mattes61 [ Fri 16. Oct 2020 20:55:41 ] |
Post subject: | Re: Question about additional SRXL2 Satellites... |
Hello Tomáš, Have I something misunderstood ? Can I attach the normal DSMX-Satellites at the Sat-ports or can I really attach an additional SRXL2-satellite at the sat ports but how ? I see in the Shop no adeqate cable to attach for example from sat port 1 or 2 to an SRXL2-satellite - Please can you give me for clarifcation an answer, maybe I understand this here not right ? Thanks ! BR Matthias |
Author: | ZeXx86 [ Fri 16. Oct 2020 21:05:41 ] |
Hello, you can connect SRXL2 satellites at the SAT ports. We will make available the cable, hopefully on monday. So for example you can connect up to 3x SPM4651T satellites. |
Author: | Mattes61 [ Fri 16. Oct 2020 21:51:52 ] |
Hello Tomáš, thanks a lot for your fast response and great support ! BR Matthias |
Author: | Mattes61 [ Sat 31. Oct 2020 21:47:17 ] | ||
Post subject: | Re: Question about additional SRXL2 Satellites... | ||
Hello Tomáš, sorry I know that you are very busy but I want to ask when the new SRXL2-cable (for more than one satellite) will be available in the shop ? By the way is it then possible to mix different satellites as SPM4651T and SPM9747 (both are Spektrum) Thanks a lot for your answer ! BR Matthias
