It is currently Sun 24. Nov 2024 8:52:19
PostPosted: Tue 22. Sep 2020 10:51:38
Question, now i'm using the governor of my Kontronik Kosmik, can i use the Spirit governor with it?
I link the Tellme Jeti for the telemetry on the Spirit RS.
but i don't know where i find the rpm to plug on the Spirit RS...
Does somebody use his spirit with Kosmik for Governor?
And what is better? Kontronik gov or spirit gov?
Eric
PostPosted: Tue 22. Sep 2020 15:55:02
Hi Eric, do you have this cable? https://store.spirit-system.com/en/acce ... cable.html
If I read correctly you do. Use Sat 1 Port. Just leave the Spirit Governor disabled but Enable telemetry in Advanced page--Telemetry. Use Kontronik TelMe.
You will need to use Prog Unit to make sure the Telemetry parameters are correct in the ESC.
I have used the Kontronik ESC Govs in all my (3) equipped Helis and they are good.
PostPosted: Wed 23. Sep 2020 7:48:26
No i'm using the telme Jeti from the Kosmik and plug on E1 (or 2?), the telemetry works well, no problem.
But i don't know how to to use the rpm signal on EI/2 for the Spirit GOV...
Eric
PostPosted: Wed 23. Sep 2020 8:13:34
If you have telemetry working Ok then I would just use the Gov in the ESC. Which I do, It's good.
PostPosted: Wed 23. Sep 2020 10:14:06
Yes me too, but i would like to know just for my information.
Eric
Users browsing this forum: Bing [Bot] and 31 guests
