Spirit System
[SOLVED] Castle Creations Phoenix Edge HV 80A
https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=4241
Author:  latjo-k [ Mon 24. Aug 2020 10:00:58 ]
Post subject:  [SOLVED] Castle Creations Phoenix Edge HV 80A
Hi
A couple of questions abaout this esc,i plan to use the governor in spirit unit the white cable from cc goes to the
pit pin in unit ok.But the manual says connect a resistor 10Kohm betwen the white and the red cable for use
telemetry?Else use the telem cc cable?I can only se brown red orange on this cable and a shrinktube in the middle.
I cant understand this?
Can anybody explain?
//Latjo
Author:  ZeXx86 [ Mon 24. Aug 2020 10:17:06 ]
Post subject:  Re: Castle Creations Phoenix Edge HV 80A
red and orange wires are same as white and red.
Pit cable is for rpm sensing for governor. It is 4th wire. And also there is secondary bec cable.
Anyway we highly recommend to get telem cc cable.
Author:  latjo-k [ Mon 24. Aug 2020 10:47:55 ]
Ok
I order a telem cc cable,whth that the white cable connects direct to the pit pin(for rpm)and the throttle cable
connects to telem cc cable and the telem cc csble goes to Trottle on spirit rs unit?
am i correct?
//Latjo
Author:  latjo-k [ Mon 24. Aug 2020 10:58:33 ]
hi
The telem cc cable is on backorder?
//Latjo
Author:  ZeXx86 [ Mon 24. Aug 2020 12:26:53 ]
Yes, you are correct. Yes, cable is not in stock, but we will produce them within 1-3 days.
Author:  latjo-k [ Mon 24. Aug 2020 14:42:03 ]
HI
Is it then ok to put the 10Kohm resistor between the red and orange cable?
//Latjo
Author:  ZeXx86 [ Mon 24. Aug 2020 14:42:53 ]
Yes, this is OK if done properly.
Author:  latjo-k [ Mon 24. Aug 2020 14:58:17 ]
OK
Thank you Thomas
Author:  latjo-k [ Fri 04. Sep 2020 7:25:31 ]
Hi
The esc is up and running,difficult to get it to arm,find a video on web.
Governor working ok and telemetry displays all data as it should.
//Latjo
http://www.phpbb.com/
