It is currently Sun 24. Nov 2024 12:16:48
PostPosted: Wed 15. Apr 2020 14:57:15
I am using the Spirit Configuration Software v3.0. When I try to open the log, I get an error message that no valid PDF-reader was found on my system.
The Adobe PDF viewer is installed (default folder "C:\Program Files (x86)\Adobe\Acrobat Reader DC\Reader\AcroRd32.exe"). The PDF viewer normally works fine and is setup to open .pdf files by default.
Has anybody an idea what the problem might be?
PostPosted: Thu 16. Apr 2020 13:37:22
I did some further investigation.
The following conditions apply to my system:
  • Windows 10 (German Language)
  • Documents folder moved to D:\Dokumente (using the properties of the documents folder)
I monitored the Spirit Settings process with Procmon (SysInternals). There I can see, that the Settings tool creates a new PDF-file in my D:\Dokumente folder, but then tries to open C:\Dokumente\spirit-log-....pdf. The drive letter changes from D to C. On C the folder Dokumente and the logfile do not exist. But if I look manually into my documents folder on D, there the logfile exists and I am able to open it using the Explorer. It just does not work from the Spirit Settings tool.
2020-04-16 14_31_44-Process Monitor - Sysinternals_ www.sysinternals.com.png
2020-04-16 14_31_44-Process Monitor - Sysinternals_ www.sysinternals.com.png [ 39.33 KiB | Viewed 287 times ]
PostPosted: Thu 27. Aug 2020 14:01:50
Same for me: my document folder is in the F drive.
Thanks for spotting this and all the investigation: based on your analysis I could easily find the PDF and open it manually. Would be nice to solve this minor issue though.
PostPosted: Fri 28. Aug 2020 21:28:01
Same for me from the very beginning almost 5 years ago and never been fixed since. Not a great deal but frustrating.
PostPosted: Thu 03. Sep 2020 12:14:36
you can try this software: http://spirit-system.com/dl/settings//s ... -win32.exe
Hopefully it will help.
PostPosted: Fri 04. Sep 2020 18:45:03
Actually better, at last. Thanks a lot.
PostPosted: Fri 04. Sep 2020 18:53:44
Thank you.
Better or resolved?
PostPosted: Fri 04. Sep 2020 19:12:28
Both Sir ! :lol:
Users browsing this forum: No registered users and 50 guests
