Frsky Taranis X9 Lite S - Spirit Unit - How to check ESC? https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=4230 |
Page 1 of 1 |
Author: | Mike_Snoo [ Wed 19. Aug 2020 13:16:56 ] |
Post subject: | Frsky Taranis X9 Lite S - Spirit Unit - How to check ESC? |
Hi all, I recently bought a used Helicopter Alzrc X360 with a Spirit FBL Unit, connected with S-Bus to a FrSky X4R receiver. I bought as well a brand new FrSky Taranis X9 Lite S. I updated the receiver and sender to the latest firmware. I can't get the ESC to work and wonder if the wiring is wrong. The ESC has a 4 cables, Black, Red, White, Yellow. Black, Red and White go to the FBL unit Channel AUX. The Yellow cable goes to ELE/PIT/AIL on the middle of the 3 pins. Looking forward to any help. Mike |
Author: | p.i.engineer [ Wed 19. Aug 2020 13:58:20 ] |
Post subject: | Re: Frsky Taranis X9 Lite S - Spirit Unit - How to check ESC |
you need to calibrate the throttle. |
Author: | Mike_Snoo [ Wed 19. Aug 2020 15:06:23 ] |
Thanks, how do I do that? |
Author: | ZeXx86 [ Wed 19. Aug 2020 19:15:19 ] |
First please assign Throttle channel - General/Channels window to Channel 1. Then it can already work. If not, then calibrate throttle range as described in the instructions of the ESC. |
