It is currently Sun 24. Nov 2024 10:54:46
PostPosted: Mon 17. Aug 2020 11:40:58
Hello Unisens does not work for me on the Spirit RS at port E1.
The port in the RS is on EX bus.
With my Jeti Rex6 I have to set it to Jetibox / Sensor so that the sensor was recognized.
That doesn't work with the RS, it just has
EX bus
EX bus input / backup or
PPM
Now I have to take the Ext and unfortunately the connector of the sensor has to be split.
It's not that nice.
Jeti DS-12 software 5.03 Spirit RS Firmware 3.1.0
greeting Heli
PostPosted: Tue 18. Aug 2020 8:21:57
E1 can be configured to JETIBOX/Sensor in the Device Explorer/REX-RS.
Please set this option, then it should work in the same way as with EXT port.
EXT port is configured for JETIBOX/Sensor permanently.
E1 is configured to JETIBOX/Sensor by default actually.
PostPosted: Tue 18. Aug 2020 13:35:44
I do not get any telemetry data either. YGE sapphire,
REX-RS and DS16.
I have connected port 1 to the YGE controller
Everything was copied into the device directory as described.
It's just strange that it always worked with the same components in the Spirit 2 and SpiritPro ...
Greeting
PostPosted: Tue 18. Aug 2020 13:48:14
Port must be configured to JETIBOX/Sensor otherwise it will not work. Also you have to set JETI Telemetry in the ESC, not YGE telemetry.
If you would use Spirit ESC telemetry, then it is YGE telemetry and also wiring is different.
PostPosted: Tue 18. Aug 2020 14:04:29
I have set JetiExBus in the YGE controller!
I have set E1 EXBus in the Spirit RS!
In the DS16 transmitter I copied the Rex-RS folder in the device.
nevertheless I do not get any telemetry data displayed in the DS16!
PostPosted: Tue 18. Aug 2020 14:06:59
No, please set JETIBOX/Sensor to E1 port.
PostPosted: Tue 18. Aug 2020 14:22:58
ok, changed to JetiBox/Sensor.
No telemetry ...
PostPosted: Tue 18. Aug 2020 14:33:43
We will make a guide. Certainly it will work.
PostPosted: Tue 18. Aug 2020 16:43:33
today E1 placed on JetiBox / Sensor.
Telemetry with the Unisens is now working.
thank you
PostPosted: Tue 18. Aug 2020 16:59:13
You are welcome.
Users browsing this forum: No registered users and 59 guests
