Spirit System
[SOLVED] Spirit pro with govenor and spectrum multi adapter
https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=4227
Author:  mb-1953 [ Tue 18. Aug 2020 11:38:25 ]
Post subject:  [SOLVED] Spirit pro with govenor and spectrum multi adapter
Just checking to be sure that I am going in the right direction. I am using a Hobby wing rpm sensor which I am powering at 3.3volts from the sat port. The sensor output is being connected to the pit terminal of the ele/pit,ail port. I am using the multi adapter to connect 2 sats, the single wire of the multi adapter connects to the ail pin of the same port.
Can they work together?
Author:  ZeXx86 [ Tue 18. Aug 2020 13:10:18 ]
Post subject:  Re: Spirit pro with govenor and spectrum multi adapter
yes, looks good.
Author:  mb-1953 [ Tue 18. Aug 2020 14:33:50 ]
Thank you, Tomas.
http://www.phpbb.com/
