It is currently Sun 24. Nov 2024 13:04:12
PostPosted: Tue 11. Aug 2020 14:21:12
I have a Spirit 2 with a YGE with Telemetry turned on. I have used this configuration with a DX9 and was working well with 9 channels. Now i am moving to a IX12.
The 6610T is connected to the Spirit2 using 3pin Port1 (instead of 3 PIN SRXLport on the side) and the 4651T is connected to the 6610T using the 4 wire min connector.
I switched to my IX12:
When i select channel 11 and 12, i can’t control these 2 channels. They stay at 0 versus going to +100 and -100. Is they’re something that i am doing wrong ?
I tried to make sure all the other channels available in the screen may be mixed up with no success.
Here is a picture of the Spirit interface you can see channel 11 is at 0:
PostPosted: Tue 11. Aug 2020 20:58:38
Make sure your radio is set for 22ms. You can only use 10 channels with 11ms frame rate.
PostPosted: Tue 11. Aug 2020 21:40:53
Thanks LogoX2. Setting at 22 ms works !
I must say i have learned a lot with the SRXL2 modules.
Users browsing this forum: No registered users and 76 guests
