Spirit System
Android Spirit Settings Bank switching
https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=4201
Author:  weixelgeist [ Fri 07. Aug 2020 9:49:38 ]
Post subject:  Android Spirit Settings Bank switching
Hi
I am on Android Spirit Settings 3.1.0 with Wifi-Link
I cannot find out how to switch the Banks, the app is always on Bank0
Thank you, Gerhard
Author:  ZeXx86 [ Fri 07. Aug 2020 10:10:17 ]
Post subject:  Re: Android Spirit Settings Bank switching
It is enough to swipe the screen to the right side.
Author:  weixelgeist [ Fri 07. Aug 2020 10:26:01 ]
It works, thank you.
Another question:
I have set the Wifi-Link Modul to 60sec Auto Switch Off
But the modul does not switch off.
Author:  ZeXx86 [ Fri 07. Aug 2020 10:35:55 ]
You have to disconnect from the module.
If you have set up also Wifi Client then you have to disconnect client - or go away from the AP.
Author:  weixelgeist [ Fri 07. Aug 2020 11:28:31 ]
Ok, I got it.
Thank you
Author:  amelin@macks.be [ Mon 12. Apr 2021 9:22:53 ]
I have the same problem, not able to change bank !
Android on One T 7 plus.
Swiping to the right, up, down or left, there is no swipe possible.
Swipe what ? All screen ? Just a specific place of the screen ?
Thanks for help.
Author:  JoergZ [ Fri 14. Apr 2023 10:24:56 ]
it is an old task but i have today the same irritation...
I had the same problem of being able to view the banks by swiping to the right.
Navigating by swiping was enabled on my ONE+. This reliably prevents this menu function from 'Spirit-Settings'.
I switched to 'navigation via symbols' and then >swiping from left to right< is working and i am able to select Banks...
New phones no longer have navigation icons. Please show an info about it. Perhaps also simplify switching B0/B1/B2 via fixed icons in the upper area.
Greetings
Author:  ZeXx86 [ Sat 15. Apr 2023 7:34:32 ]
no buttons are needed to access the menu.
You only need one finger - put it at the left side, center of the screen and then move to right. This will open the menu.
http://www.phpbb.com/
