Hobbywing Telemetry https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=4194 |
Page 1 of 1 |
Author: | Manfred [ Mon 03. Aug 2020 17:54:05 ] |
Post subject: | Hobbywing Telemetry |
Dear all, coming from Brain/Jeti, changed to Spirit RS. Before all telemtry data where valid/trustful Changed to Spirit RS (nice FBL, like it) with Hobbywing 120a V4 All datas are valid except Temperature. Is much to high. Hobbywing Prog-Box shoes 25°C, but Spirit starts with 38°C. Under flight spirit shows up tp 106°C (But in reality isn`t) ----------- Changed to a huge brandnew ESC, Hobbywing 130a V4 ) on same Motor. Again, under normal climate condition (office room) starts with 38°C. Under flight up to 138°C (But in reality isn`t, you can touch the ESC) ----------- Can you check your software please. It seems (sure) that spirit is calculate/use wrong figures. With best regards Manfred |
Author: | ZeXx86 [ Mon 03. Aug 2020 18:40:32 ] |
Post subject: | Re: Hobbywing Telemetry |
Hello, temperature reported by Spirit with HobbyWing ESC is internal from FET transistors. These can reach temperatures even near 150°C. This is all OK. It seems people are confused by this. So we consider to change it to external temperature. |
Author: | HeliMLM [ Tue 04. Aug 2020 14:39:19 ] |
Hello Tomas, i've just done a little test: Hw 80A v4... telemetry signal connected to: 1. j-Log S32 => Rex3: "FET temp." reporting 27-28°C on bench directly after startup, stays solid for 1-2 minutes test 2. Spirit 2 => Rex3: reporting 35.7 - 35.8°C on bench directly after startup, stays solid for 1-2 minutes test check with laser temp. gun: room / bench / heli / esc: all around 26-27°C ... so i guess there IS something with the temperature measurements... i've repeated 3 times both versions alternating. always same result. |
Author: | Kluftinger [ Tue 04. Aug 2020 19:09:58 ] |
I have similar results with HW 25A and 40A V4 ESC. When I start the system at 25-27 °C room temp, the first reading for the FET temp in telemetry window is 37-39 °C. Depending on the position of the ESC (unter the canopy or outside on the frame) I see 55 up to 80 °C During hovering an ESC on the frame gets up to 75 °C due to the missing air flow. |
