It is currently Sun 24. Nov 2024 12:55:46
PostPosted: Wed 29. Jul 2020 7:26:16
I have a problem with my tail setup when stab. scale is activated.
I set up endpoints in limits tab but after switching to stab scale the tail limits left and right changes to probably 50% is this normal behavior?
Verstuurd vanaf mijn SM-A520F met Tapatalk
PostPosted: Wed 29. Jul 2020 7:41:20
This is because your Gyro Gain is very low in this mode. Please increase the Gain. Then it will be OK.
You can compare Gyro Gain between these modes in the Diagnostic tab. Ideally they should be same.
PostPosted: Thu 30. Jul 2020 14:45:15
Hello, i tried but i think this is not the case.
I am building a scale heli and set gyro gain bij he testflights by tx. Gain is now the same in every flight mode/ bank. The tail range changes something but not much
gr kees
PostPosted: Fri 31. Jul 2020 19:34:55
When in the same bank i switch in the setup in the stabi tab from stabilisation normal to scale and changes nothing els the tail slider range changes to max 50% of the range in stab normal..
could anything else be the reason for this behavior?
Users browsing this forum: No registered users and 80 guests
