It is currently Fri 22. Nov 2024 14:55:25
PostPosted: Fri 09. Jan 2015 19:33:51
Hello!
I have on question. When the governor Feature will come in feature releases, can i use it with a normal reciver or must I use a Satelite?
Because the throttle is conectet to the reciver.
And where will the RPM sensor be connected?
thanks Andreas
PostPosted: Fri 09. Jan 2015 19:58:29
governor feature should be available very soon.
All necessary information will be described in the manual and this forum, so stay tuned.
But generally ESC with built-in RPM output will be the best choice.
PWM connection will be only one, that is not supported for Governor operation. All other should work.
