It is currently Sun 24. Nov 2024 10:24:46
 Post subject: Telemetry HW wiring
PostPosted: Sat 25. Jul 2020 17:35:25
Tomas will the new hw wiring work with spirit telemetry for spektrum?
https://www.amainhobbies.com/hobbywing- ... 1/p1208251
Sent from my SM-T580 using Tapatalk
 Post subject: Re: Telemetry HW wiring
PostPosted: Thu 30. Jul 2020 20:46:00
The telem UNI cable (for HobbyWing 'HW') contains no electronics. Simply connect as follows:
HW Red - DO NOT CONNECT !! Remove this wire.
HW orange -> Spirit sat port, centre pin
HW brown -> Spirit sat port, outer pin.
If it doesn't work, swap the brown wire to the other outer pin on the spirit.
PostPosted: Fri 14. Aug 2020 2:34:03
Is connecting the brown cable necessary? or can just the orange cable connection work to send telemetry data without the brown wire? The data comes from the orange wire, and the ground connection is the same ground that comes from the other cables that go from the ESC to the FBL.
I know on other brands only the signal wire needs to be connected.
Users browsing this forum: Google [Bot] and 59 guests
