It is currently Tue 26. Nov 2024 16:34:15
PostPosted: Sun 08. Nov 2020 4:30:56
I see in the release notes that Hobbywing ESC temp is now ambient (as opposed to FET before?). However, temp readings appear the same (I was expecting much lower?), is there a new telemetry variable I need to use instead now?
Thanks!
PostPosted: Sun 08. Nov 2020 10:25:23
there is no other telemetry variable. Temperature you can see should be correct.
PostPosted: Sat 14. Nov 2020 1:13:22
Thank you. All appears good, looks like either the ESC or the Spirit itself sends a max value of 100 when the telemetry is connected, and I was checking this. During a flight, the actual temp value didn't go over about 48, and it would have been over 100 before the update. Thanks for making this change.
