Spirit System
[SOLVED] After Crash Spirit Pro is not working
https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=4118
Author:  thgeisel [ Fri 03. Jul 2020 14:13:15 ]
Post subject:  [SOLVED] After Crash Spirit Pro is not working
After a crash I took the Spirit Pro from the crashed heli and moved it to a new one.
Evry thing is working fine , I can bind it to the transmitter , I can access the Unit with the program, the servos move with the sticks of the transmitter.
Only when I turn or move the heli, there are no reaktions as usual. None of the servos shows any reaktion.
Is there anything I can do to repair it ??
Author:  ZeXx86 [ Fri 03. Jul 2020 14:37:08 ]
Post subject:  Re: After Crash Spirit Pro is not working
yes, I believe it is possible.
Please send me private message with Serial number you can see in the Connection tab.
Then we can check where the problem can be.
Thank you.
http://www.phpbb.com/
