Spirit System
Device Explorer - REX-RS settings not available
https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=4038
Page 1 of 2
Author:  Till [ Sat 06. Jun 2020 14:58:46 ]
Post subject:  Device Explorer - REX-RS settings not available
getting my new RS - so one little problem.
In the device explorer I cant enter the REX-RS settings (unable to open configuration), the spirit settings are available.
And in the heli tuning menu the spirits settings are not displayed, so you have to open the spirits settings via the device
explorer.
Firmware RS: 3.1
Jeti DC16 V1 (5.03)
Any tips for that ?
Thank you :-)
Author:  dogbreath [ Sat 06. Jun 2020 16:24:40 ]
Post subject:  Re: Device Explorer - REX-RS settings not available
Do you have the proper jeti.bin and the images file? Everything should be version 3.1.
Dan
Author:  Till [ Sat 06. Jun 2020 16:48:54 ]
Perhaps it is the transmitter software, it is 5.03, but Jeti Studio said there is a newer one, I will update and report again..
Author:  Gerrybru [ Sat 06. Jun 2020 17:43:16 ]
Hallo,
the software 5.03 does not have the rex3rs.bin also not with it.
I hope Tomas can provide these too.
Gerald
Author:  Till [ Sat 06. Jun 2020 17:54:22 ]
Still no luck :cry:
Update to the newest Transmitter software, copied the newest spirit.bin
No, i dont have a rex3rs.bin - where can i get that file ?
Author:  Fortune7 [ Sat 06. Jun 2020 19:19:42 ]
Till wrote:
Still no luck :cry:
Same here - no access to the Rx part of the RS unit........I'm looking at the Spirit RS manual (3.1) and the pictures shown are different from what I have on my Tx (DS-12). I have the Spirit-3-1.zip file, extracted and copied to the Devices folder in the Tx. There's no Rex3RS.bin file associated.
Cheers, Andy
Author:  ZeXx86 [ Sat 06. Jun 2020 20:12:31 ]
required file will be available on monday.
But there is nothing needed to set if you dont need a backup receiver.
Firmware for radios are not available yet oficially. Only in radios from our store. But it will be released shortly.
Author:  Fortune7 [ Sat 06. Jun 2020 21:04:22 ]
Thanks, Tomas.
I want to use a MUI EX sensor with the Spirit RS, connected at the EX port. I believe I need the EXT port for the RPM signal from ESC.
When connecting a sensor to a REX3 receiver I have needed to configure the receiver port for the sensor, and assume I need to do the same with the RS. I tried connecting it and then selecting AUTO in telemetry / sensor setup, but it doesn't detect it.
I can certainly wait till Monday for the file. Thanks again,
Andy
Sent from my SM-T510 using Tapatalk
Author:  Till [ Sat 06. Jun 2020 23:17:09 ]
And we need the access to set the correct filesave positions.
>In the Basic Properties menu select Heli to Spirit and continue to another page. (Please note transmitter update 5.04 is required for this option - only available in DS-12 Spirit Edition at the moment).
Thank you to make that clear.
Monday is perfect - because it is raining heavily here :?
Author:  ZeXx86 [ Mon 08. Jun 2020 17:43:24 ]
here is updated archive with required files:
http://spirit-system.com/dl/jeti/SPIRIT-3-1-RS.zip
All will work after copying at the Devices directory.
http://www.phpbb.com/
