Stabi Correction Parameter https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=4036 |
Page 1 of 1 |
Author: | FrankFuss [ Sat 06. Jun 2020 5:09:42 ] |
Post subject: | Stabi Correction Parameter |
The description of the new Stabi Correction parameter says that "For models with a high vibration level it is recommended to leave default settings. (Disabled)" . I notice that the 3.1.0 Vibration telemetery has changed and now records a higher level. What vibration level counts as a "high vibration level" with the new Vibration telemetry? |
Author: | ZeXx86 [ Sat 06. Jun 2020 8:26:03 ] |
Post subject: | Re: Stabi Correction Parameter |
Hello, you will see event in the log when vibrations are over 100%. Stabi Correction is sensitive rather for high frequency vibrations so with a smaller helicopters that are vibrating a lot there can be problem when enabled. But otherwise this feature can make the rescue even more precise in all other situations. |
