It is currently Sun 24. Nov 2024 15:00:48
[ 7 posts ] |
john1127
Posted: Sun 14. Jun 2020 19:54:56 |
anybody else have problems with position hold not holding at all. Always want to go left and backwards. swash level,flys fine with position hold off. thks
Posted: Sun 14. Jun 2020 20:23:20 |
first from all you have to check that when you tick Servos/Subtrim (tuning) all servo arms will be really centered.
Then make sure that swashplate is really level at the same time. And then make sure that there is 0° between main blades.
If all this is OK, please engage Stabilisation (Normal), (Acro) or Coaxial. Then check that when it is engaged, helicopter will not tilt anywhere. It should be level and stable.
If all this is OK, Position Hold should work perfectly.
If model is going somewhere else or in a circles with Position Hold/RTH/GeoFence, then compass calibration is not OK. Or value for Compass Heading Correction is not 0°.
john1127
Posted: Fri 19. Jun 2020 3:43:48 |
Hi T well I took the geo off the 600 and put it on the 450 . recalibrated and checked all Heli flys stable off the bat. Engaged geo to stabilize and take off ,it does the same as 600 wont hold on new position only to where I took off from ?? compas is within 1 degree. horizontal 90 verticle 90. Is there anything else I can do. Thks John T
buttles
Posted: Fri 19. Jun 2020 7:42:49 |
If you are on 3.1 have you set the 4th Tx position on RTH? Perhaps you think the Geolink is setting the home position when it powers up where in fact the Geolink is remembering the manually set position?
john1127
Posted: Fri 19. Jun 2020 13:38:58 |
Im on 3.1 and 1.2 and no I only have pos hold activated. Only flying 3 ft in altitude.sometimes I need full colective to fight heli going back to original lift off postion. longer I fly the harder it trys to go back. Im also under support named (GEO).
buttles
Posted: Fri 19. Jun 2020 14:37:31 |
Sorry, I misread your original post. But it's odd it wants to try and go back to the take off point.....(that's where I probably thought of RTH not pos hold!)
Posted: Fri 19. Jun 2020 14:39:38 |
Can you please share your settings file?
This would be helpful
[ 7 posts ] |
Users browsing this forum: tomsl and 57 guests |
