SCORPION TRIBUNUS 06-80A ESC SBEC - support https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=4005 |
Page 1 of 1 |
Author: | Pking [ Tue 26. May 2020 19:32:12 ] |
Post subject: | SCORPION TRIBUNUS 06-80A ESC SBEC - support |
Hi, i want to buy the SCORPION TRIBUNUS 06-80A ESC SBEC model and turn the telemetry on. In the list posted in the support page, only the 120A are supported but i am sure theyre should not be any difference with the 80 Amp that was new in 2019. So is this 80A model supported and compatible even if it's no in the list. Thanks Supported models Model Battery Voltage Battery Current BEC Voltage Consumed Capacity ESC Temperature RPM Scorpion Tribunus 06-120A (SBEC) ✔ ✔ ✔ ✔ ✔ ✔ Scorpion Tribunus 06-120A (OPTO) ✔ ✔ ✔ ✔ ✔ ✔ Scorpion Tribunus 14-200A (SBEC) ✔ ✔ ✔ ✔ ✔ ✔ |
Author: | Helibelly [ Tue 26. May 2020 22:26:12 ] |
Post subject: | Re: SCORPION TRIBUNUS 06-80A ESC SBEC - support |
Hi, I have one and telemetry works fine. The bec is not great though, only good for micro servos really. Eric |
Author: | Pking [ Wed 27. May 2020 3:13:30 ] |
Helibelly wrote: Hi, I have one and telemetry works fine. Thanks Helibelly, for the bec information, i want to use it with a Oxy4 max.The bec is not great though, only good for micro servos really. Eric Is the maH calculation precise to warn me when battery consumed and I should land ? Envoyé de mon iPad en utilisant Tapatalk |
