It is currently Sun 24. Nov 2024 16:58:14
PostPosted: Tue 12. May 2020 15:03:54
Hi hope you are well, I am trying to setup my Spirit 2 with Geolink on a G500 I am switching from a SK-540 I am using 180 horizontal position and have 1 DMSX sat on the SAT2 port and GEOLINK on the SAT1 port all looks fine I changed all of the Spirit software to DSMX G500 and adjusted the tail freq in spirit Bound the DSMX to the unit blink then solid 11ms in DX18 and I am getting nothing in terms of RC input I do not have any input from TX it says Bound on Radio and the light goes solid on DSMX Sat I started with a new model and rebound it a few times but Im not sure why all seems to work BEC tester worked the subtrim tab moves the servos but no link to radio when it says bound? any help would be helpful Thanks Im stuck here
PostPosted: Tue 12. May 2020 15:26:37
If you have rescue set up, switch the rescue off then give the sticks a try. This happens all the time to me while connected to the software.
PostPosted: Sat 23. May 2020 14:24:55
Thanks I did have stabi and rescue set up I will switch them off and let you know if that was it thanks
Users browsing this forum: No registered users and 37 guests
