Settings Question for Diabolo 600 https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=3987 |
Page 1 of 1 |
Author: | yufasa [ Wed 20. May 2020 19:15:36 ] |
Post subject: | Re: Settings Question for Diabolo 600 |
I would suggest to go fly with defaults, except for rudder delay that I would lower closer to 0 if not 0 as this impacts tail stability. I also like to increase the Sensor/cyclic Rotation Rate but maybe just up the General/Flight Style value first to see how she handles. Once you fly a couple of flights note what you don’t like and go back to tune it - these things are almost all about personal preference so it is touch to give you values that will just work for you. |
Author: | Mattes61 [ Thu 21. May 2020 9:40:09 ] |
Hi, thanks for your reply ! I will try it like you said, the rudder delay have I changed to "0", I think that should be ok - For the a rough starting point I would have been interested in whether I can choose the average between the two diabolos (550/700) or whether I am totally wrong. I was already flying in the basic setting, but it felt a bit robotic, so I think I have to raise the flight style by one point - It is true roll rate and head gain are to be adjusted according to personal preferences - LG Matthias |
