It is currently Sun 24. Nov 2024 17:08:25
PostPosted: Tue 26. May 2020 15:00:55
Is it ok to leave the Bluetooth/WiFi modules permanently connected to the FBL and mounted on the heli? Or should they be removed after each use and/or not flown while plugged in?
PostPosted: Tue 26. May 2020 15:22:19
I know it is OK to leave the BT module on and there was some discussions on the Wifi module too as it now has the ability to auto disconnect. With that said, I would rather use the integration to my radio that have the module connected, but that I guess depends on the radio you are using...
PostPosted: Thu 28. May 2020 4:46:04
I had integration set up on my DX8 and it was usable but I preferred the Interface provided by the wifi Module on my phone I’ll be moving to Jeti soon and it looks like integration is a bit more developed so it might be a non-issue
Thanks for your input!
Users browsing this forum: No registered users and 22 guests
