Possible to open log of older firmware with newer software? https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=3954 |
Page 1 of 1 |
Author: | maddog7 [ Fri 08. May 2020 21:16:08 ] |
Post subject: | Possible to open log of older firmware with newer software? |
Hey all, I'm trying to look at the log on my friends Spirit, I have ver 2.8 software on my (Linux) machine and will change his firmware to 2.8 if his unit looks ok but I'd like to retrieve the log from the unit if possible to see if there is any info about what might have caused his crash. I think it was power loss after the BEC became unplugged, would there be any way to acertain from the log that this had happened? When I start the software it says that the unit has firmware 1.0.25 which is obviously very old. Can I download this version for either Linux or Windows somewhere or if I update the unit to a version the software will talk to will the log be wiped or unreadable? Any thought greatly appreciated. Cheers D |
Author: | ZeXx86 [ Sat 09. May 2020 16:19:14 ] |
Post subject: | Re: Possible to open log of older firmware with newer softwa |
Here is the Spirit Settings 1.0.25: https://www.spirit-system.com/dl/settin ... -win32.exe I can send you Linux version too. |
Author: | maddog7 [ Sat 09. May 2020 20:54:07 ] |
Hi Tomas, Thank you for that, unfotunately I think because I've power cycled the unit prior to using the software you've provided, the log from the crash has been lost. No worries though, I think it was the power becoming unplugged that caused the issue anyway. I'll just update it to 2.8 and see how it goes, the sensor readings seem perfectly stable! Thanks for the assistance Cheers D |
