hi
files attached the logo 550 has a wag into the wind.
the logo 690 had a big tail shake on the ground
as for expo I used it on vbar control no problem helped a lot with my flying ment I did not have to move the sticks as far,because it was not sensitive enough at mid stick so I used expo to correct it.
thanks
logo550 1.4ds [255 Bytes]
Downloaded 22 times
logo690 1.4ds [255 Bytes]
Downloaded 15 times
logo550 2.4ds [255 Bytes]
Downloaded 25 times
ZeXx86 wrote:
for sensitive collective pitch please decrease your Collective Pitch range. This is the only correct solution. Expo at pitch is not recommended and has no good meaning.
For tail wag please send your 4ds settings file and all details about your model. Then I can help you more.
