It is currently Sun 24. Nov 2024 15:44:11
Page 1 of 1
[ 5 posts ] |
Author |
Message |
Rocala
Posted: Fri 01. May 2020 14:52:34 |
Hello, I have mount for test a Spirit Pro with Geolink on a Trex500xt. Spirit is in firmware 3.0.0 and Geolink is in firmware 1.1.0 Radio Futaba T18MZ, Receiver Futaba 7008SB Fasttest, connected in Sbus to the Spirit. Channel 1 Throttle unassigned (Connected directly to the receiver). Channel 2 Aileron - Channel 3 Elevator - Channel 4 Rudder - Channel 5 Gyro Gain. Channel 6 Pitch - Channel 7 Bank - Channel 8 Stabi I only use Bank 0 and I configure Stabi to Coaxial Mode. That's work. The problem is when i try to activate a function of Geolink ... I specify that the Geolink is calibrated and it display where i am in MAP View. BUT when i try to activate one of the function : Postion Hold, Altitude Hold or Return to Home via a switch on the Channel 9 ... nothing happens ... And worse if I release this switch Channel 9, I'm not coming back to Stabi mode ! If anyone can advise me ... thank you
Top |
helijürgen
Posted: Fri 01. May 2020 18:14:45 |
Spirit falsch konfiguriert.Den wenn du Schalter aktivierst,muss im Geo die Aktivierung oder Schalterstellung sichtbar sein.
Gruß Jürgen
Top |
Rocala
Posted: Sat 02. May 2020 13:31:47 |
Hello, No the Geolink is correctly configured. In Diagnostic, switch channel 8 => stabilisation coaxial active and switch channel 9 => Geolink active (Pos Hold) When I active Pos Hold nothing happen and then when I deactivate Pos Hold => Stabilisation coaxial is out !!! So what can I try to solve this problem ?
Top |
Posted: Mon 04. May 2020 22:10:54 |
Site Admin |
are you trying these features at home? I recommend to try anywhere outside.
Also you can check if you can see GeoLink feature engaged at the Diagnostic tab (nothing else should be engaged).
Top |
Rocala
Posted: Tue 05. May 2020 8:51:55 |
Hello Zex, You tell me (nothing else should be engaged) I suppose when one geolink feature is engaged ! It's OK ? So stabi mode + geolink does not work together ? And if it's true, i have to deactivate first stabi mode before activate a geolink feature ? Thank you to clarify
Top |
Page 1 of 1
[ 5 posts ] |
Who is online |
Users browsing this forum: No registered users and 53 guests |
