It is currently Sat 23. Nov 2024 20:36:35
Page 1 of 1
[ 2 posts ] |
Author |
Message |
Storchy
Posted: Tue 21. Apr 2020 17:08:57 |
Is it possible to make new telemetry sensors for GeoLink GPS real position and GeoLink RTH position. That would be perfect to check the RTH function in a LUA script an disable / enable RTH functionality in TX
i have RPM [RPM] - Current RPM from the Governor. Fuel [%] - Vibrations of the model (Reported as Fuel) RB1V [V] - Main Battery Voltage RB1A [A] - Main Battery Current RB1C [mAh] - Main Battery Consumed Capacity RB2C [V] - BEC Voltage (10x) - set Ratio 25.5 Tmp1 [°C] - ESC Temperature 5120 [μs] - Throttle PWM Value
perhaps add
GGPS[Table] GRTH[Table]
Ciao Jörg
Top |
Storchy
Posted: Mon 28. Jun 2021 10:40:48 |
Perhaps it is possible to get the count of sats as a sensor. I have a switch to hold position, and i only want to use it if there a enough sats
Top |
Page 1 of 1
[ 2 posts ] |
Who is online |
Users browsing this forum: No registered users and 43 guests |
