V3 firmware test was ok https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=3892 |
Page 1 of 1 |
Author: | ferdey [ Mon 20. Apr 2020 0:39:41 ] |
Post subject: | V3 firmware test was ok |
Hi, I had the v3 firmware loaded anyway so today I had some nice weather and tested it out. On my Align 550X, with the tilted skids, I did have to do the CTRL-ALT-U thing to get the rescue mode to work with a level swash first. However, it flew perfectly and testing rescue from a hover upright and inverted worked as it should. |
Author: | ferdey [ Mon 20. Apr 2020 1:55:23 ] |
Post subject: | Re: V3 firmware test was ok |
2nd flight also all good on a Goblin 570 Sport. I didn't have to recalibrate this one, I've replaced the G10 frames with the CF ones and these don't add the forward tilt. |
Author: | latjo-k [ Mon 20. Apr 2020 15:30:06 ] |
I also tested my ver 3.0 spirit pro today in the air,but it whas not ok.At safe altitude in Hoover i hit the rescue sw, and heli rolls to the right.Sekond attempt,heli going downvards.No crash i was very alert to switch off the rescue. i have going thru all tests at the bench and Everything has looking fine but in the air it dont works. i have also done the calib process with unit leveled whith a spiritlevel. How far away is the new safe ver3? thanks //Lars |
Author: | Butscher [ Mon 20. Apr 2020 17:29:29 ] |
I have tested v 3.0 on a compass exo, The problem with the helicopter is that you have to switch it on upsidedown, and then put it on the skids. In rescue, the Ts is crooked, If I leave the helicopter then about 20 sec. the Ts in rescue straight and in flight is also no problem |
Author: | ferdey [ Mon 20. Apr 2020 20:37:50 ] |
Interesting that we're all seeing such different results with v3. I've tested 4 helis with good results now on v3. I am going to continue to treat rescue with suspicion, though, until we hear something official on it. |
Author: | scvflyer [ Tue 21. Apr 2020 9:55:23 ] |
Post subject: | Re: V3 firmware test was ok in some of my helis |
Just as feedback for someone - and Thomas I used V3 on Spirit Pro and didn't find any problem on: - TREX 600 - Align BL Servos - EXO 500 - MKS Servos - Oxy2 Lynx Servos kind regards Siggi |
Author: | ferdey [ Fri 24. Apr 2020 0:53:28 ] |
Small update - I just had 2 flights on my 700X. One the first one, whilst spooling up, it did look like it was going to slowly tip over to the right. I just took off and the flight was ok. I also tested rescue, and it did appear to slant towards the left slightly. 2nd flight was ok again... |
