It is currently Sun 24. Nov 2024 20:30:16
PostPosted: Thu 02. Apr 2020 2:06:32
First of all, I’m no FBL king......still learning
I’ve put a Spirit FBL on my Blade 360 3s and have been flying it.
Recently, after some tail rotor damage, repaired the heli and realized my TR was rotating the wrong direction. I fixed that today by reversing Ch4 in the FBL
While trying to test that, upon spool up, I’m getting NO CP while in Normal Mode. There is collective in IU1 and 2 however.
The Tx monitor shows it is sending a throttle and CO signal when operating the left stick
Can someone point me in the right direction where I need to look in the FBL pls?
PostPosted: Thu 02. Apr 2020 2:42:33
Do you have bank switching enabled?
Sent from my SM-G965U using Tapatalk
PostPosted: Thu 02. Apr 2020 3:24:56
Thx for the reply
I’m sure I 'did' because it used to fly in all three modes
Where do I look to see if bank switching is enabled? I didn’t see that.
Are Banks like flight modes? Or different?
PostPosted: Thu 02. Apr 2020 17:58:41
check your pitch curves in all flight modes
PostPosted: Wed 15. Apr 2020 17:46:53
grant22 wrote:
Thx for the reply
You should be able to see if anything is engaged by looking at the diagnostic screen or one of the tabs. Towards the bottom itll have things like "bank switching- not setup" or something to that extent. Same goes for rescue or special function. Itll all show on that page.
Bank switching is like flight modes except you can have multiple performance settings changed between the different modes to see which one is best or for different flying types. Like you could have piro comp setup as 160 in bank 1, 170 in bank 2 and 180 in bank 3. Or like for rescue, you could have bailout on bank 0, coaxial on bank 1 and nothing in bank 2.
Users browsing this forum: No registered users and 63 guests
