couple questions https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=384 |
Page 1 of 1 |
Author: | leatherface [ Wed 10. Dec 2014 22:01:25 ] |
Post subject: | couple questions |
spirit is set up,but noticed on the workbench when i hit aileron stick full travel left or right,the elevator servo will suddenly move quite a bit,but only when at aileron limit.is it possible i have to much aileron travel?not really sure what to check to fix this.also when rescue acro is set will the spirit apply negative or positive pitch depending which way up it is after rescue switch is hit? |
Author: | ZeXx86 [ Wed 10. Dec 2014 22:22:46 ] |
Post subject: | Re: couple questions |
Which receiver connection do you use? If you move only with aileron, elevator servo shouldn't move at all. Yes, Rescue Acro is working in the inverted flight as well. Be sure you have configured collective pitch for the rescue correctly. |
Author: | leatherface [ Wed 10. Dec 2014 23:22:23 ] |
hi,i use spectrum satellite connection.i initially binded to dsmx but weird things were happening in diagnostics page,so i tried binding to dsm2 and that worked,so currently binded to dsm2. |
Author: | ZeXx86 [ Wed 10. Dec 2014 23:32:49 ] |
Good. Then I guess your Cyclic Ring limit is too high that servos are binding or are out of their travel. Try to decrease this parameter. |
