It is currently Sun 24. Nov 2024 17:55:18
 Post subject: Spectrum Analyzer
PostPosted: Wed 01. Apr 2020 23:49:57
Can someone please explain the difference in desired reading for bench test as described in the manual (main and tail blades removed) and in flight?
I run the Analyzer on the bench with all blades removed and I get very good readings in all 3 axis. Out of curiosity in flight I take snapshot of each x and y axis and see result has extreme vibration over 100. Heli seems to fly ok. Small occasional tail wag 1-2 inch. Should I be worried? I still need to capture Z axis in flight.
My thoughts are that on bench test without blades it shows very little vibes so I think my heli mechanics is good. Only possibility left would be main or tail blades? They are perfectly balanced (i think).
Any clarification would be appreciated.
File comment: Z Bench
File comment: Y Bench
File comment: X Bench
 Post subject: Re: Spectrum Analyzer
PostPosted: Wed 01. Apr 2020 23:57:31
These are in flight captures...
File comment: Over 100 on the left hand spike.
Users browsing this forum: Helihello and 64 guests
