It is currently Sun 24. Nov 2024 19:51:32
[ 2 posts ] |
jjuk
Posted: Tue 31. Mar 2020 19:09:31 |
Rescue hover pitch is selectable from 0 to 100%.
Is that a percentage of total pitch range or of positive pitch range?
If set to 0, is that full negative pitch or zero pitch?
If set to 50%, is that zero pitch or 50% of positive pitch, e.g. 6 degrees if max pitch is 12 degrees?
10x
Posted: Tue 31. Mar 2020 20:21:24 |
Depends on how you have rescue set. If set to normal it will roll upright and give you 40%(default) of your positive pitch. If set to Acro it will give you 40% positive pitch if upright, but if inverted it will give you 40% minus pitch.... You would need to try this to make sure the % selected would allow your heli to hover...
[ 2 posts ] |
Users browsing this forum: The Gasman and 44 guests |
