It is currently Sun 24. Nov 2024 18:42:48
PostPosted: Sun 15. Mar 2020 20:26:26
I followed the directions and made the 10k ohm resistor part and it seems to be working fine. This was on an Oxy3 using a uSpirit. I only had 1/4 watt resistors. It would seem like there isn't going to be much current in this connection but wanted to post this question.
Is 1/4 watt sufficient?
PostPosted: Tue 17. Mar 2020 22:29:26
yes, it should be enough. It is only for signal path where nearly no current is present.
Users browsing this forum: No registered users and 34 guests
