Spirit System
SRXL2 setup problem - Oxy3 - uSpirit
https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=3794
Author:  Bladecrasher [ Sat 29. Feb 2020 4:51:52 ]
Post subject:  SRXL2 setup problem - Oxy3 - uSpirit
I have an odd situation and need help. I had a perfectly fine and flying setup using an old DSMX Lemon sat before the change to SXRL2.
I wanted to try Telemetry, so I have a 4650 wired up and connected to my uSpirit. I have flashed 2.8 on the unit. I have been through the Wizard.
When I power up the system everything "almost seems" correct. Roll, Pitch, and Rudder and Rescue all work as expected.
But when I move the left stick on the DX9, I get no collective on the swash.
In the Diagnostics page, I have +-100 when I move the TX stick, so it seems like the uSpirit is "seeing" my channel input correctly.
When I disable HOLD, the head spools up.
Other than collective, it seems like I'm ready to fly it.
Attached is my configuration file.
Any thoughts on where I have gone wrong?
oxy3_srxl2_uSpirit_022820.4ds [255 Bytes]
Downloaded 49 times
Author:  Alyon187 [ Sun 29. Mar 2020 4:26:14 ]
Post subject:  Re: SRXL2 setup problem - Oxy3 - uSpirit
You need to reverse your gear channel. I'm guessing its thinking your in rescue mode. I had to reverse mine when I got went w srxl2. Saw the same behavior.
Sent from my SM-G965U using Tapatalk
Author:  tfmcnellist [ Sun 29. Mar 2020 23:16:59 ]
I had to reverse the gear channel also. I found that sometimes after a change while programming the collective does not respond. I have to hit rescue, the system goes through the rescue sequence and then everything moves as normal.
http://www.phpbb.com/
