It is currently Sun 24. Nov 2024 19:32:49
Post new topic Reply to topic  [ 4 posts ]
PostPosted: Sun 23. Feb 2020 22:09:24
I have 3 Spirit units, on 3 different sized helis.
The Oxy3 and Gaui X3 can work with a single 4650T without worry I believe. Using the information here (http://manual.spirit-system.com/index.p ... 2C_SPM9747) and either your purchased adaptor cable or a home-made version seem straightforward.
Is there some significant difference between the 4651T and 4650T, or is the case the only change?
On a 600 size heli where I would be more comfortable with a second signal receiver source how do I wire something like this up if the SAT ports on the Spirit Pro don't work any longer? Do I need to purchase a separate RX so that I can plug the 9747 in, or can I wire up 2 of the 3 SRXL2 type units somehow via the Spirit? It would be great if I could just use 2 of the 4650T units, but I'm guessing the 9747 is required as the second receiver signal source.
Thanks for reading my post.
PostPosted: Sun 23. Feb 2020 23:13:52
The SPM 4650t is fly-by telementry only were as the spm4651t is full range. If you want more than one rx, on a big heli i think the best way would be to have a AR6610t rx with a SRLX2 sat plugged in to that. I would use an SPM4651t as i already have 2 of them...You could use a SPM9747 if you wish..
PostPosted: Mon 24. Feb 2020 1:24:50
What does fly by telemetry mean?
PostPosted: Mon 24. Feb 2020 14:08:27
Short range, only receive on your tx when you fly close...
Users browsing this forum: No registered users and 70 guests
