It is currently Sun 24. Nov 2024 21:20:53
 Post subject: Gps Holder for My Oxy3
PostPosted: Sat 18. Jan 2020 14:33:45
Hello
I would like to buy a gps module, for now I think I will use it on Oxy 3, which has a tube/tail diameter of 12 mm. Which support / holder should I use for the gps queued on my oxy 3?
PostPosted: Sat 18. Jan 2020 14:44:28
it will hold without a holder. Supplied double sided tape might be enough.
Holder adds weight too what is not good for small helicopters.
PostPosted: Sat 18. Jan 2020 14:56:45
Thanks for your answer, Tomas!
but I have doubts if the little contact surface(tube/tail)(because it is not an extended flat surface) is a good solution for double side tape....and the gps case...in the end I would only use 1/3 of the entire surface of the gps cover, with the double side tape on my tube/ tail.
It seems to me an approximate solution .
of course the holder weighs and you're right.
PostPosted: Sat 18. Jan 2020 15:01:47
give a look to the mounting suggestion in the manual ;-)
http://manual.spirit-system.com/index.p ... k_Mounting
PostPosted: Sat 18. Jan 2020 15:10:21
Hello Urgno, mine is just a test montage on the Oxy3 then I will take it on a 700 class, but I still want a fixed support for the gps. I have to manage somehow
PostPosted: Sat 18. Jan 2020 22:29:47
use the supplied tape it will be fine. I use this method on both Oxy 3 & 4 with no issues.
PostPosted: Sun 19. Jan 2020 16:00:10
Hi LogoX2
Today I bought my first spirit GPS module. As soon as it arrives I ask you for help and impressions. Thanks
PostPosted: Wed 22. Jan 2020 8:55:26
if you have a friend that can 3d print for you
here you find a lot of supports:
https://www.thingiverse.com/search?q=geolink
Users browsing this forum: No registered users and 25 guests
