Spirit System
Governor Setup
https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=3707
Author:  Helibelly [ Tue 07. Jan 2020 22:18:07 ]
Post subject:  Governor Setup
Hi, I am about to setup the governor on my Goblin 380, and have a couple of questions.
Firstly, in the max head speed box, is this calculated using 3.7 v per cell, making 22.2 v for my 6 cell lipo?
Secondly regarding the gear ratio, my heli has a gear ratio of 5.45, but the Spirit software only goes to one decimal point.
I know this is only a small difference but it would be nice to have it as exact as possible.
Can this be addressed in a later firmware update?
Thanks, Eric.
Author:  Helibelly [ Fri 10. Jan 2020 22:44:45 ]
Post subject:  Re: Governor Setup
Just a bump to see if I can get an answer at some stage.
Eric.
Author:  ZeXx86 [ Sat 11. Jan 2020 9:32:20 ]
Max Head Speed is simply value you can get at 100% TC with governor disabled.
Yes, it is so small difference that RPM readout is way under the threshold. So it would make zero change in the behavior.
Author:  Helibelly [ Sat 11. Jan 2020 13:47:44 ]
Thanks for the reply. Regarding the max headspeed figure, obviously one does not actually fly the heli at 100% throttle curve with no governor to see the max headspeed it can achieve!
So it must be a calculated value. Which brings me back to my original question, what cell voltage is used in this calculation?
I am assuming that it is 3.7v per cell, but would like to confirm before setting up the governor.
Thanks, Eric.
Author:  10x [ Sat 11. Jan 2020 14:00:14 ]
Castle creations use a nominal figure of 3.7v per lipo cell for their gov settings....
Author:  Helibelly [ Sat 11. Jan 2020 22:09:24 ]
I think this must be it as 3.7v is usually what is called the nominal voltage.
I just wanted it confirmed by the man himself to be absolutely sure.
Eric.
Author:  ZeXx86 [ Sun 12. Jan 2020 9:46:23 ]
Yes, it is true, because it should be the lowest average voltage during flight.
Author:  Helibelly [ Sun 12. Jan 2020 14:00:41 ]
Great, I will use this value.
Eric.
http://www.phpbb.com/
