It is currently Mon 25. Nov 2024 0:40:10
[ 4 posts ] |
wcp
Posted: Fri 10. Jan 2020 1:52:03 |
I go to "General / Cannels" I assign "F:Stabi Function" to 8" then I go to "Stabi tab" and set Stabalistion (Normal) In my DX9 I assign Aux3 = Channel 8 then I assign channel 8 to switch (G). I can see in the Diagnostic tab "Stabi on and off with my switch. This will give me when the switch is on Stbai in normal mode. I do not use bank switching so this would all be in bank 0. Do I understand this right ? WCP
Posted: Sat 11. Jan 2020 19:15:35 |
yes, you are right.
If you can see it is acting in the Diagnostic tab it will work properly.
wcp
Posted: Sat 11. Jan 2020 19:45:23 |
Thanks ! Can I tell if Sabi is on by looking at the heli and moving it around ? What might notice different with Stabi on and off ? WCP
Posted: Sat 11. Jan 2020 19:48:19 |
You will see it in the Diagnostic tab as Engaged.
It is possible to distinguish behavior of the swashplate, behavior is little bit different. Always return to the center.
[ 4 posts ] |
Users browsing this forum: No registered users and 67 guests |
