It is currently Mon 25. Nov 2024 0:01:11
Post new topic Reply to topic  [ 15 posts ]  Go to page 1, 2  Next
PostPosted: Thu 19. Oct 2017 18:00:14
Is it possible to get the log file after a fly when the spirit unit is connected with Jeti EX bus (Rex reveiver) and kontronik telemetry is activated ?
Logo 600 sx spirit, Diabolo 700 spirit pro, Jeti DS 14.
France.
PostPosted: Thu 19. Oct 2017 18:03:02
Yes, you can log each flight and store it directly at the sdcard in your transmitter.
Later you can re-view it in the radio or on your PC.
PostPosted: Thu 19. Oct 2017 18:15:35
Thank you for the answer.
Do not know how to register the log file on the SD card with jeti radio, but I shall go to my workshop and try this.
France.
PostPosted: Thu 19. Oct 2017 18:18:13
It is enough to press the REC button. Then it will start logging, similarly as on a camera when recording video.
PostPosted: Thu 19. Oct 2017 21:05:41
May be there is a misunderstanding: I am speaking about the spirit fbl unit log file , in order to see if cycling ring limits are reached in flight for example.
France.
PostPosted: Fri 20. Oct 2017 2:14:52
If you are referring to the health logs that are captured every 10 seconds, that would be nice to have on the Jeti radio. Right now, to view the every 10 seconds logs requires a computer.
PostPosted: Fri 20. Oct 2017 11:43:44
Yes, this is possible just with FrSky at the moment. But we believe it will be possible with Jeti in some way too in upcoming updates.
You can also view it by a smartphone/tablet.
PostPosted: Sat 21. Oct 2017 16:33:26
ok, it would be useful.
It is not very safe to switch off the tx while the rx is stil powered to be able to get the spirit log file on my phone. ( As I use kontronik telemetry from the spirit unit).
The other way to get easily the spirit log on a phone is to buy a Telme Jeti and to disable kontronik telemetry in the spirit settings, but I do not want to buy a Telme Jeti, :roll:
France.
PostPosted: Sun 22. Oct 2017 9:36:36
We will find a way how to make it work.
I believe that in update 2.6 it will be available.
PostPosted: Tue 29. Oct 2019 4:20:45
Sorry to dig up an old thread but it is relevant to my question. Is there now any way to view spirit flight log files in the jeti TX before shutting off spirit?
Users browsing this forum: Bing [Bot] and 47 guests
