It is currently Sun 24. Nov 2024 22:49:27
 Post subject: Goblin 280 and Telemetry
PostPosted: Wed 20. Nov 2019 12:20:01
Hallo togehter!
I'm trying to set the telemetry on my Goblin 280. In the tab for the gear ratio I would have to enter 1: 1, but this will not be saved. Can someone tell me what I have to enter here for the right configuration?
Thank you and best regards
Robert
PostPosted: Wed 20. Nov 2019 12:43:45
you should just enter what is stated in the Goblin manual. Then save the settings and all will be OK.
For sure correct ratio is not 1 : 1 for this model.
PostPosted: Wed 20. Nov 2019 22:01:07
hi Thomas
the ratio in fact is 1:1 because is a direct drive helicopter
the motor is coaxial to the main shaft
anyway seem the correct parameter is to put
sensing divider: 12
gear ratio: 1.00
PostPosted: Thu 21. Nov 2019 8:21:26
Yes, you are right.
I forgot to mention Sensing Divider because this is configured according the motor poles.
PostPosted: Thu 21. Nov 2019 10:55:50
Thanks to both of you. this information helped me.
Best regards
Robert
PostPosted: Thu 21. Nov 2019 16:21:25
no worries
enjoy your flights ;)
Users browsing this forum: No registered users and 67 guests
