It is currently Sat 21. Sep 2024 10:48:40
[ 5 posts ] |
cc1975
Posted: Tue 23. Jul 2019 12:42:06 |
Hey,
i want to fly my Goblin 570 also with low RPM. If i fly with 2100 or 2600 RPM all ok, but if i go to 1800RPM or lower i have shaking on the whole swashplate, mostly on Elevator.
Setup is Standard for G 570, Gain on Swashplate is About 50. Anyone some Idea or same Problem? Greetings Christian
thestructured
Posted: Thu 25. Jul 2019 17:41:34 |
Low headspeeds will require reduced cyclic gain and the best thing you can do is have a separate bank with this reduced gain for when you want to fly low headspeeds.
Posted: Sat 27. Jul 2019 8:12:55 |
you can reduce Geometry 6° value little bit. This could help a lot. Ideally you can use a softer main blades, for example Edge FBL or similar.
cc1975
Posted: Sat 27. Jul 2019 15:12:33 |
I have Rapid Blades, but with original SAB Blades or Zeal Blades i have the same effect. So reduce 6 Degrees geometry would be better like on 5,5 Degrees? lowering Swash gain would help also? The 6 Degrees i have to set on the blade over the tail boom Right? If i have 6 Degrees on the front blade i have 7,3 on the blade over the tail boom???? Greetings Christian
cc1975
Posted: Tue 06. Aug 2019 12:15:03 |
I reduced Geometry from 6 to 5,5 Degrees and now the shaking is gone….. will be also interesting for my upcoming Henseleit tdsf where i will have 800rpm lowest. greetings christian
[ 5 posts ] |
Users browsing this forum: No registered users and 8 guests |
