TomasN wrote:
I am using Y cable for connecting Spirit and Unisens-E to Graupner receiver without problem. But devices must be set to emulate different sensors, e.g. one EAM and other GAM. And of course you can't connect plus wire to Spirit's SYS port. I use only signal wire to SYS port, because ground is already connected by other cable.
I assume that it should be same for Kosmik.
Thank you Tomas,
I was afraid of making a kind of short circuit between the two signals this way. But if you say it works, i will try.
