It is currently Mon 25. Nov 2024 5:35:33
 Post subject: Jeti Spirit Pro issues
PostPosted: Sun 23. Jun 2019 16:52:47
Hi Guys,
This is the first time that I'm experiencing this issue. Jeti integration with spirit pro is showing some weird readings on Tx. On set up wizard Cyclic gain is set to 65, rotation rate 12 cyclic & 11 for tail. On advance menu only thing that I set was pitch pump which is 4. In device explorer it reads the fbl but on Cyclic gains & rotation rates its reads 0. In advance menu including expert settings, it's showing all sorts of figures in their respective tuning menu. What do you think is the problem ? This is my 5th spirit fbl , never experience this issue before. When connected to computer, readings are as what I had set in the wizard.
PostPosted: Mon 24. Jun 2019 7:27:44
Please update Jeti BIN file to the latest one. Then all will work well.
Users browsing this forum: No registered users and 48 guests
