It is currently Mon 25. Nov 2024 2:46:29
 Post subject: Geolink update
PostPosted: Fri 07. Jun 2019 12:05:12
I've been having a problem just like everybody else did that I can't update my geolink unit. The unit just arrived this morning. And I accidentally update it with 1.0.2 eventhough it's already got the same version (damn it). When it was updating, the spirit software froze, so I had to restart it. And the geolink isn't functioning at all.
I managed to upload 1.0.2 to geolink with recovery mode with a really quick connect and disconnect method (I have regular heli red spirit by the way), but when it reaches 100% the status says failed and the failed pop up window message comes up and the spirit software froze. I'm sad now, coz I was looking forward to fly my heli tomorrow with this geolink unit.
What should I do? I'm in new zealand by the way, bought the unit from local distributor
 Post subject: Re: Geolink update
PostPosted: Fri 07. Jun 2019 23:44:37
I had the same problem. If you have access to a Spirit Pro connect the Geo Link to it and Flash 1.0.2 Firmware.
PostPosted: Sun 09. Jun 2019 14:17:51
I managed to fix it. I had to downgrade the spirit firmware to 2.5.2 and reflash the geolink. But it's very tricky. Coz I had to plug and unplugged the cable very very very very quickly on recovery mode. And it didn't always work every time. 1 out of 5 attempts
PostPosted: Mon 10. Jun 2019 8:17:07
yes, connecting must be relatively quick. It is the best to just re-connect the cable from the GeoLink.
Then it should be basically always successfull.
PostPosted: Mon 10. Jun 2019 10:25:15
Hi Tomas,
it's looking like you may have to tweak the Standard Spirit unit to accept the firmware reset as I also had to use a Pro to unbrick a Geolink.
You just can't unplug and reinsert a small jst quickly enough!! Still a great product.
Users browsing this forum: No registered users and 82 guests
